Hi,
I bought an (apparently) DS-2CD3132-I from AliExpress and when it said it was PoE I expected the power would be drawn through the ethernet cable but it looks like they want a PoE splitter to power this (pic below).
There wasn't a single bit of documentation with the camera so I'm not sure what it's powered with.
The plan is to install it under the soffit and bring the ethernet the 3 meters to the unmanaged non-poe switch.
I was thinking just because I only have 1 camera, and there is a wall socket just 1 meter from where the camera will be installed… could I somehow just get a recommended power adapter of some kind and connect it directly to that camera chord, and wrap electrical tape around it to make sure there's no moisture or short that would burn down the house?
Or must I put a poe injector and splitter on both ends.
Thanks
Thanks
