- Sep 14, 2015
- 1,197
- 3,977
Worked for C&P here for a while around that same time. I hated climbing poles. I did it but I was never happy about it.
I hear ya....I got that pucker every time I went up and down 2 different airport beacon towers to change out the beacon lamp, they were about 75 ft. tall.Neither very high up, maybe 20-25ft but that'll put the pucker in ya!
No never got used to it, I could do it but like you never really liked it. Burnt a couple, one at pole climbing school in Houston and one out in the sticks of Kansas. Neither very high up, maybe 20-25ft but that'll put the pucker in ya!
I swear when the wind blew and the tower swayed ever so slightly my subconscious tried to evolve a third hand out my bung hole to grasp a rail!
I was young and stupid back then.Now that’s working at heights. More than I’d probably be willing to try
The big ones like that don't move much, it's more the clouds going by that gives you the feeling of movement.
When you get on some of the small ones like home towers for TV and ham radio, that's when you have to climb to the sway, or it will eat you alive.
I have been 1800' or so up, but had an elevator up the first part of the way. I think the highest I have climbed was around 800'. This was many years
back before you had to be tied off 100% of the time. It was almost worse riding the winch line up and down. You had to make sure you never caught
on anything going up or down, the winch would never stop in time to save you. The fast way down was to put a pully over the top of the lower guy wires,
then use your boots to slow you down on the way. Thank goodness for steal shanks.
I still have my hooks from pole climbing school, thank goodness I didn't have to use them much. I burned an old well splintered pole about 25'
up and ended up with a splinter right through my right nipple. I sure did some screaming once I looked around and made sure no one else was there.
Right. We’re talking about a 1/3 of mile in the sky there. I’m pretty sure I’d freeze up and be stuck well before thatOk I got nauseous 1/2 way through this paragraph
I learned early on when in a 35 foot bucket truck to find a fixed object like the street light fixture and stare at it while ascending and looking up for other obstacles, wires, etc., the clouds can give you vertigo and instill a false sense of movement.The big ones like that don't move much, it's more the clouds going by that gives you the feeling of movement.
