- Apr 30, 2016
- 216
- 15
So my ptz are non POE just 12v and i'm not sure what cable to use my Power Supply box says to only use 18awg copper also
but the only problem is i'm not sure what to use as i run only cat 6 to the cam but power is a problem since it will be in the roof can i just use auto cable 2mm 2 core
or can i use this http://www.ebay.com.au/itm/100-M-Ro...433038?hash=item25a5526f4e:g:z-cAAOSwhOVXe1II
the runs are about 35m max or less
just not sure which cable to use just for 12v power
