My first post here to this great forum, I have been reading and came across a thread where a user had issues for using port 80 on the NVR as it was pulling up the camera on his mob app, since it was using the same port.
I would like to avoid this from the start by learning the correct port scheme from you guys.
The setup will be a none poe 32ch NVR with 10 or so IP cameras connected to a POE Netgear switch.
Will this scheme of port forwarding work?
NVR HTTP port to 90
RTSP port to 9554
Server port to 9000
IP cam port to 80
Also, if I dont need to watch the cams directly, do I still need/should to port forward their port? which will be 80.
Do you recommend a better port forwarding scheme for none POE NVR.
Thanks a bunch in advance.
Cheers
NVR HTTP port to 90
RTSP port to 9554
Server port to 9000
IP cam port to 80
Cheers
