- Mar 8, 2017
- 81
- 10
I've noticed for awhile after an old android app update that the wan connection was slow to connect and load vs the speed on lan but I put up with it and double notifications for the same alert for awhile. I don't know if that helps at all but suddenly I can't connect at all by wan now.
Thought it was due to the newest mobile app update because I was still able to connect to wan while on lan until I realized it doesn't work at all outside of the network. I keep getting a "connection timed out" error whether on mobile, web or canyouseeme.
I can't figure out why the port forwarding just closed on its own on this RT-AX88U, while still showing the rule and the setting enabled. I didn't do any thing except maybe a new windows update but no settings were changed anywhere and it was all working fine. I just suddenly noticed the app wasn't pushing notifications then saw the issue.
There's nothing special about the setup at all regarding VPN, DNS, HTTPS etc. I've tried rebooting router by power cable and updating the firmware, disabling windows firewall and rebooting PC etc. I was also still on V4 of BI but I went to 5.5.7 and it's still the same. Again the forwarding rule was working fine and it's still there without issues on port 81. I changed it all to 8181 but it's still timing out.
Pretty stumped here any ideas?
*Remote Access Wizard/Test all green except failing the final test that checks the external port is visible to internet.
