T Tazz 316 Getting the hang of it Aug 11, 2016 263 54 Aug 12, 2017 #1 Been getting issues port forwarding for instance if i open port 805 on my router and have it go to the ip of my camera and go to a site like canyouseeme it says that port is not open. Why is that?
fenderman Staff member Mar 9, 2014 36,891 21,408 Aug 12, 2017 #2 Tazz 316 said: Been getting issues port forwarding for instance if i open port 85 on my router and go to a site like canyouseeme it says that port is not open. Why is that? Click to expand... port forwarding is a huge security risk...use vpn..search this forum
C C0m4 Young grasshopper Nov 1, 2015 24 3 Aug 12, 2017 #3 You shouldn't mess with ports below 1024 unless you know what you are doing. As per additional security via VPN - it is nice as long as customers are willing to pay for it. Sent from my SM-A720F using Tapatalk
fenderman Staff member Mar 9, 2014 36,891 21,408 Aug 12, 2017 #4 C0m4 said: You shouldn't mess with ports below 1024 unless you know what you are doing. As per additional security via VPN - it is nice as long as customers are willing to pay for it. Sent from my SM-A720F using Tapatalk Click to expand... Port number is meaningless... Above or below 1024 makes no difference.... VPN is free on most consumer routers...
T Tazz 316 Getting the hang of it Aug 11, 2016 263 54 Aug 12, 2017 #5 The is for only one camera no PC only a router and modem. Nothing else gets used on this network.
fenderman Staff member Mar 9, 2014 36,891 21,408 Aug 12, 2017 #6 Tazz 316 said: The is for only one camera. Click to expand... Number of cameras is irrelevant
T Tazz 316 Getting the hang of it Aug 11, 2016 263 54 Aug 12, 2017 #7 I see the write up about VPN but once you turn it on in the router how do you pull up a camera with a IOS app. BTW i also use blue iris at my home and do not have port fowarding on expect for blue iris. Last edited: Aug 12, 2017
fenderman Staff member Mar 9, 2014 36,891 21,408 Aug 12, 2017 #8 Tazz 316 said: I see the write up about VPN but once you turn it on in the router how do you pull up a camera with a IOS app. BTW i also use blue iris at my home and do not have port fowarding on expect for blue iris. Click to expand... you would need to use a vpn client on your phone...i think ios has one built in..there are threads that discuss this.
T Tazz 316 Getting the hang of it Aug 11, 2016 263 54 Aug 12, 2017 #9 I will keep looking then. Am i right with blue iris you only have to use port fwd to it instead of each camera that you have? So it would be a little safer,
