- Aug 8, 2016
- 11
- 0
Ok, please bear with me, while i got my cameras working a couple of years ago but they sat on a bench (working day in and day out) and then as of about 9 months a go in a box.
I am now in the middle of commissioning the system for real.
Last time i had all this setup I was using HIDDNS to register the cameras and I thought I was using uPnP to open ports (but i am not sure) - i was alo testing blue iris. Ok so now my re-noob questions.
1) Anyone have any idea why when uPnP is enabled on 5.4.0 there are more than just 8000 opened? Is there a way to control that - also the UI refers only to HTTP, RTSP and Server Port it seems to open more than that if one enables it. Specfically:
[TABLE="class: { 'is-not-responsive': portForwardStatsListCtrl.columnStore.getCustomized() || !portForwardStatsListCtrl.isResponsive() }, width: 962"]
[TR="class: ng-scope"]
[TD="class: portForwardStatsName ng-binding"]IPC_RTSPTCP[/TD]
[TD="class: portForwardStatsSrc ng-binding"]Anywhere[/TD]
[TD="class: portForwardStatsProto ng-binding"]TCP[/TD]
[TD="class: portForwardStatsPort ng-binding"]8200[/TD]
[TD="class: portForwardStatsForward ng-binding"]192.168.1.53[/TD]
[TD="class: portForwardStatsForwardPort ng-binding"]8200[/TD]
[TD="class: portForwardStatsRxPackets ng-binding"][/TD]
[TD="class: portForwardStatsRxBytes ng-binding"][/TD]
[TD="class: portForwardStatsLeaseduration ng-binding"][/TD]
[TD="class: switchStatsActions appTableCell--actions"][/TD]
[/TR]
[TR="class: ng-scope, bgcolor: #FAFAFA"]
[TD="class: portForwardStatsName ng-binding"]IPC_HTTP[/TD]
[TD="class: portForwardStatsPort ng-binding"]10001[/TD]
[TD="class: portForwardStatsForwardPort ng-binding"]80[/TD]
[/TR]
[TD="class: portForwardStatsName ng-binding"]IPC_Control[/TD]
[TD="class: portForwardStatsPort ng-binding"]10003[/TD]
[TD="class: portForwardStatsForwardPort ng-binding"]8000[/TD]
[/TR]
[TD="class: portForwardStatsName ng-binding"]IPC_RTSP[/TD]
[TD="class: portForwardStatsPort ng-binding"]10002[/TD]
[TD="class: portForwardStatsForwardPort ng-binding"]554[/TD]
[/TR]
[/TABLE]
It is annyon the UI shows only 3 but 4 are opened. Plus doesn't include the HTTPS I would want to open... just looking for someone to confirm if this is normal and if there is way to be more granular.
2) I assume if i want more than one camera enabled then i need to map each 8000 internal port to a different external port. What i don't see when using HIDDNS is a way for that server to know (and as such IVMS seems to assume its 8000 and then connect all devices to that one 8000 port)
3) Can someone verify the uPnP settings in the UI when set to manual don't work? Everytime i set them manually and come back to the page they show as default and 'not valid' despite my gateway showing the ports were opened (a ubiquiti USG).
4) lastly when using uPnP nothing works, i cannot connect to the stream, if i turn off upnp and force a manual mapping then all is OK. I am trying to work out if this is an issue with my gateway or with IVMS..
(and yes i know all about upnp in general so please lets not turn this thread into a upnp pros/cons debate, thanks)
[/TR]
[/TR]
[/TR]
[/TR]
[/TABLE]
