Check these two photos out. The photos are of the same vehicle passing through the capture area of the camera. The vehicles license plate is significantly clearer when it just enters the cameras view on the far right side.
You can see as the camera passes from right to left, when its right in the center of view, the license plate becomes significantly less clear. During the day with a vehicle adhering to the speed limit, this is not a problem. During low light and with high speed vehicles, reading the plate becomes problematic.
link to the camera that I'm using:
You can also see that the grass and asphalt is much clearer around the edges vs in the middle. I keep the focus pulled so that the plate is readable closer to the edges because thats about where the AI runs but just wondering if there is anything to be done about this or if I should just buy a new camera. (which is why I posted that thread where I was considering a different camera: Has anyone tried this camera? Amcrest License Plate Recognition (LPR) Camera)
