I have mounted a HikVision DS-2CD2732F-I dome camera vertically outside. I am getting poor image quality in terms of brightness and I cannot save modified brightness settings on the camera directly.
I have a proper wall mount but I am not using it because I want the camera to be less conspicuous for aesthetic reasons. It is not a security camera. It is a camera just to allow me to see the nice view of the bay when I am not there, which is a lot. I know dome cameras are not ideal outside and supposed to be mounted vertically. This is the setup I had with this particular camera elsewhere and it worked fine in terms of the image quality.
A sample of the image is attached. This is a morning capture looking intro o the sun, but it is still too dark during the day. Night is useless with the IR, the image is almost totally grey. I haven't figured out why yet. It was fine in the other location, but is a secondary concern.
I am wondering if it is because the lens is rotated 90 degrees (It's full rotation) and the sensors are pointing out to sea, to the sky, and it can't get a good reading for brightness. When it was mounted on the wall mount looking at the driveway at the other house, it was good image quality day and night.
I do not have an NVR. That is on it's way. I can save many of the camera's settings, but the Configuration, Basic or Advanced Configuration, Image, Display Settings tab where the brightness settings are located does not have a Save button.
So there are three problems - brightness level, not being able to save a different setting and the night time IR (Which might be just because it can't reflect off anything?) But the main one is not being able to save a change. Is this because I don't have an NVR connected to it?
