- Feb 17, 2016
- 5
- 0
Evening / Morning all..
Bit of a lurker - but first time poster. I've managed to glean load of really useful info.
I currently have a 3 camera setup and this will soon be 4..
In daylight, whether sunny or overcast, the images are crystal clear.
However, as soon as the cams switch over to IR mode at night - quite clearly I haven't got enough ambient lighting to make a decent picture.
The nearest streetlamp is about 10 metres away and is on the opposite side of the street.
Ideally I'd rather not have to wire in spotlights, but if needs must then I can.
I've seen IR illuminators that I can connect to my POE switch.
My question is do you think that its a suitable idea?
Ignore the cable in the top left - that won't be there much longer.
I am unable to connect directly to each camera as I am using an embedded NVR and I have no idea how to change each setting.
Cheers in advance,
Tom
Cheers in advance,
Tom
