Poor AI Detection Speed
bethzur
May 19, 2021
103
57
Pennsylvania
I have an RTX 3050 in my PC with an i7-7700. I see AI detections take 500-1300 ms. That seems longer that it should be by at least an order of magnitude. I checked the logs and it claims it's using the GPU. I'm using yolov8s for the model. I seem to recall DeepStack was 100 ms or less. Has anyone else seen this or any tips to troubleshoot. I may try 8n which I'm guessing should be faster. I am using the main stream, so the images are like 2880x1530 but Google AI thinks that should be around 100 ms.
Here is a sample from the logs. There are no refrigerators in the image.
Code:
T-767 msec  [1446 msec]
        "api":"primary",
        "found":{
            "success":true,
            "error":null,
            "message":"",
            "predictions":[
                    "category":4,
                    "label":"refrigerator",
                    "confidence":0.718442559242249,
                    "x_min":1095,
                    "x_max":1451,
                    "y_min":411,
                    "y_max":799}
                    "category":4,
                    "label":"skis",
                    "confidence":0.449722796678543,
                    "x_min":1687,
                    "x_max":2030,
                    "y_min":834,
                    "y_max":1115}
                    "category":4,
                    "confidence":0.441071748733521,
                    "x_min":640,
                    "x_max":1188,
                    "y_min":3,
                    "y_max":1125}
                    "category":4,
                    "confidence":0.415100038051605,
                    "x_min":1077,
                    "x_max":1341,
                    "y_min":772,
                    "y_max":1040}
            "count":4,
            "moduleId":"yolov8s.onnx",
            "executionProvider":"ONNXRunTime: 3 (NVIDIA GeForce RTX 3050)",
            "analysisRoundTripMs":1015}
Code:
        "api":"primary",
        "found":{
            "success":true,
            "error":null,
            "message":"",
            "predictions":[
                    "category":4,
                    "x_min":1095,
                    "x_max":1451,
                    "y_min":411,
                    "y_max":799}
                    "category":4,
                    "label":"skis",
                    "x_min":1687,
                    "x_max":2030,
                    "y_min":834,
                    "y_max":1115}
                    "category":4,
                    "x_min":640,
                    "x_max":1188,
                    "y_min":3,
                    "y_max":1125}
                    "category":4,
                    "x_min":1077,
                    "x_max":1341,
                    "y_min":772,
                    "y_max":1040}
            "count":4,
Do not use main stream, it does not improve accuracy, it just slow down the detection.
I did not. Where is that?
Read this post for location and instructions that I posted earlier!
Reactions: bethzur
