Polycarbonate/Acrylic dome replacement
Jahua95
May 25, 2020
100
40
Florida, USA
I am looking for replacement polycarbonate/Acrylic dome for my IPC-HDBW5231E-Z cameras did anyone find a source for this?
Is the dome severely scratched, shattered or broken? Or is it just pretty fogged up from UV and smog?
Foggy and dull light is scattered
OK...I ask because if you are never able to find the right replacement dome I was thinking that one of the higher-rated automotive headlight restoration kits available on Amazon might clear it up for you. For under $20 it may be a viable solution. :cool:
CERAKOTE® Ceramic Headlight Restoration Kit – Guaranteed To Last As Long As You Own Your Vehicle – Brings Headlights Back to Like New Condition - No Power Tools Required - 10 Wipe Kit
