I have a Cisco 3560 Catalyst 24port POE switch that I use for my 5 POE camera's that was gifted to me from work. I am looking at various PTZ camera's now and they require the POE+, my switch will deliver upto 15 watts per port. Is there an adapter or a hack that anyone knows of where I could combine two ports to get POE+ or should I just go find a POE+ injector. What do you pro's do when you go from 802.3af to 802.3at for just one PTZ?
I may consider going down to a 8 port POE+ switch to save on power from this old rackmount 24 port switch, any recommendations there (I would want at least 6 POE's).
Thanks
Beek
Thanks
Beek
