M mwhitnell n3wb Nov 12, 2015 19 3 Jul 24, 2020 #1 I have a poe switch without uplink port and wish to connect to a remote poe, do I just make a crossover cable?
biggen Known around here May 6, 2018 2,808 3,211 Jul 24, 2020 #2 Any straight through patch cable will do. We have had auto crossover switch ports for ages now. Reactions: Broachoski, TonyR, SouthernYankee and 1 other person
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,336 48,154 Alabama Jul 24, 2020 #4 biggen said: Any straight through patch cable will do. We have had auto crossover switch ports for ages now. Click to expand... Yep, for over 22 years now, according to patent held by HP since 1998 for Auto MDI/X. Reactions: biggen
Broachoski Getting comfortable Jun 21, 2019 652 1,626 USA Jul 25, 2020 #5 Also if your existing POE switch contains any non POE ports then you could use one of those also to connect to the new switch.
