- Dec 26, 2016
- 84
- 21
Thanks encouragement help I have started down Blue Iris paths I now have POE question
Currently have 8 port BV gigabit Switch with 130 power budget and I need mover POE ports (as will no longer be using the POE ports in my NVR)
Should I replace it with a BV-Tech 18 Port PoE+ Switch (16 PoE+ Ports (10/100)| 2 Gigabit Ethernet uplink) power budget 130W
(Slower and lower power budget)
Or just add another 8 port BV gigabit Switch with 130 power budget
Thank in advance for the Advise
