I have a POE switch connected to 6 outdoor cams. I was going to add a new camera so I used an additional POE injector to set up the camera indoors. I connected the new IP cam to the router re no problems. However, all of the other cameras died and could not see any cams on the network.
I rebooted the router and POE switch but still see nothing. I checked the external camera cabling with one of the cheap POE detectors and get flashing green.
We did have storm but I checked the outside cameras and didn't see any obvious water filtration. I brought in one of the cameras and it seemed to light up with injector.
Questions:
1) How can I tell if the POE switch is bad ?
2) Is there a cable tester that would help determine if there is a short, etc. on one the leads?
Thanks
Questions:
Thanks
