- Nov 1, 2016
- 4
- 0
Hi all - been lurking for quite a while in the forums and decided it's time to join up. Just purchased my first 2 cameras (Dahua IPC-HDW5231R-Z) from aliexpress and, once they arrive, I have the low level voltage cable installer ready to go. He will be running 8 Cat6 cables to different points around the perimeter of my house. I also will set up a dedicated PC for Blue Iris, at least 6 more cameras (after learning from/playing with the first 2), and figuring out how to backup everything on my Synology NAS. My first question is: what POE switch would you recommend? I'd like to keep the price below $350 for a gigabit switch but maybe I can just buy a 4 port POE switch now and expand with another one later as I add more cameras? Any thoughts would be appreciated -- thank you in advance.
