This isn't a BI question per se, but that's what I use for all three of my cams (power use lol) — hopefully soon to be four — and couldn't think of anywhere else to ask this. So — I have a hardware/power issue.
The short of it is: Two of the three cameras (and if possible, three or four of four) are mounted in the front of the house/porch area, where the is no AC access. I have to run the ethernet cable from the basement along the outside of the house where the A/C is. For various reasons, I'm limited to one cable. So, I have the switch, injectors (no PoE router/switch, just a regular ubiquitous blue metal 4-port Netgear) in the basement, and pair of passive PoE splitters. This gets me two cams fine.
Is there any solution for more?
What I'm looking for/hope exists is a PoE-powered PoE switch that draws power from the switch in the basement. Does such a thing exist? If so, the passive splitters go, and now I have the ability add [x] (4-6, presumably) cams up front (there's a lot of street action around here, and not of the good kind) with short runs from this mythical switch. I also assume (know) that the Netgear (and individual injectors) would have to be replaced with an actual PoE switch — with one port that carries a significant bit of juice.
Is this possible? I've searched Amazon using the phrase PoE "power sourced" switch and get nada. Also, if possible, a general outlay of what such a switch will cost (and recommendations, if allowed by forum rules for a proper PoE router) would be appreciated.
Thanks in advance,
PD (Chris)
Thanks in advance,
PD (Chris)
