Hey all,
hoping my question can be answered as I can’t find any clear answers.
I am helping to fit cameras for my mothers neighbour, the router they have installed has only got 2 cat5 outputs, one is being used for a media player and the other I was hoping to use for the NVR. Simple so far.
My plan is, rather than trace 4 cat5 cables down a 20mm conduit, which has already got 2x satellite coax cables in it so space is tight.
I want to put a put a POE at the other other end of the conduit and power the camera from it. Can/will I be able to connect the network switch to the POE “out” on the NVR.
The picture may help.
Will the Power for the POE out damage the switch!
Can I turn off the POE out on the NVR off?
The nvr is an Annke N48PAW
Thanks
Thanks
