I am currently rebuilding my network.
Mostly because my network(s) are split into multiple wired networks connected via powerlan and I want to get rid of powerlan.
Currently a few cameras are connected to a switch. Unfortunately I cannot add more cables to the switch because the switch is on first floor, the wiring is though the attic and there is only a small cable channel being the bottleneck.
One solution would be to move the switch from first floor to the attic, then the bottleneck would be no more.
However: The attic is not insulated, means in summer hot in winter cold. It could be -10°C in winter, it could be 50°C in summer - I truthfully do not know because I never measured.
most of the devices I find have a operating temperature of 0-40 °C, which means for my uninsulated attic the switch would be outside the operating temperature.
I found a few Netgear devices having 0-50°C but that only makes it easier in summer, not in winter.
Are there POE switches with a wider operating temperature?
Are there other options so a standard device can be used? e.g. a insulating box providing lower temperature in summer and higher in winter?
