I have a cat 5e wire that runs to a generator about 50 feet from my house. It was a spare from when they installed the generator. I put a keystone on it and pulled it into my POE switch and got a Dahua camera operating on it just fine.
Previously, I had a POE powered ethernet switch out there as well. That got lost in a lightning storm. I wanted to put a raspberry pi out there for a weather station and maybe some backup.
I opted to buy these simple POE splitters for this go around.
www.aliexpress.com
Basically, I plug one end into two POE ports, and 4 of the wires get sent over the larger cat 5 and split back out the other. The other 4 wires come from the other POE port. I tested it locally and it worked great. You just get 100 mbp which is fine for my needs.
Upon installation, I noticed only one side of the splitter was working.
The funny this is is that the POE power is working great, but the link is not occurring on the broke port. I can move the camera/Raspberry pi to the other side and everything works great. But then the other item doesn't get link.
I bought a cheap ethernet tester, and all 8 wires appear to be working. It looks like a simple DC tester, so signal integrity isn't tested.
Amazon Sign-In
I tested the connectivity of each of the splitter/combiner inputs as well. It looks like 1-2-3-6 get passed through just fine, and 1-2-3-6 from the other port get mapped to 4-5-7-8 and back.
I redid the brown and blue wires on the keystones just to make sure it looked good. I suspect my blue/brown pair is somehow compromised...
Can anyone recommend anything else? I might buy some new keystones (I might be using cat 6 ones on a cat 5e wire)..
Is there a more elaborate tester than can help me here. I can probably ask at work if I know what to ask for.
Thanks,
Mike
2.99US $ |Poe Camera Simplified Wiring Connector, Splitter, 2-in-1 Network Cabling Connector, Three-way Rj45 Head Security Camera Install - Transmission & Cables - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
Amazon Sign-In
Thanks,
Mike
