I have these two Hikvision DS-2CD2032F-I cameras; Serial number DS-2CD2032F-I20150929CCWR544816028 and Serial number DS-2CD2032F-I20150604CCWR521641095. Both are running firmware version V5.4.5 build 170123.
Both ran fine with TP-Link POE1505 adapters for over 2 years. One stopped working. I switched out the POE1505's and the camera that stopped worked again.
Instead of replacing the TP-Link POE1505 with another one, I bought a BV-Tech POE-SW501 4 port POE switch so I can add a couple more cameras with minimal clutter.
One camera works perfectly with the switch. The other will not work. Had to go back to the remaining TP-Link POE1505 to get it back on.
I tried different cables, blah blah blah. That camera just will not connect with that switch with any cable in any port. It does turn on, but doesn't appear or connect.
The two cameras are on different IP addresses.
Any ideas, folks? I'd like to understand why it won't work and make it work!
Thank you!!!
Thank you!!!
