So there was another thread about a POE powered PIR activated IR Illuminator so it had me thinking of going in a bit of a different direction. Is it feasible to take something like this...
https://www.amazon.com/802-3af-Giga..._cp_147_3?ie=UTF8&refRID=3XKKW7G1E21M18Y7MMFS
And use any type of IR Illuminator that works off of a 12v power source like this...
https://www.amazon.com/CMVision-IRS...id=1466908687&sr=8-14&keywords=ir+illuminator
Or any other type of LED IR Light that run off 12v, but ALSO be controlled remotely or on a schedule thru your PoE Switch to turn the power off/on on command or on a designated schedule thru the switch software?
Ideally something like this is in my comfort zone as opposed to hard wiring the IR Illuminator to a constant power source activated via switch. I'm not comfortable at all with working with power lines; running and terminating Cat6 is about all I am comfortable with. I'm just curious if it is possible to control thru the switch, or if not if it would be better to purchase an illuminator with day/night detection.
