I’m running into an issue with PoE on a home setup. The cable run is close to 90m (Cat6, solid copper) and the camera sometimes reboots randomly. The switch is PoE+ (802.3at), and on paper it should be fine with the camera’s 12W draw, but I’m guessing voltage drop is the problem.
Has anyone here dealt with similar situations? Would you recommend adding a mid-span injector/repeater, or is it safer to upgrade to a PoE++ (802.3bt) switch?
Any real-world tips would be appreciated — not sure if I’m overthinking it or if this is a common issue.
