Hey,
I’m considering getting one SD49225T-HN (which requires poe+) and 3 turrets (running on standard poe).
The plan is to use these with a non-Poe nvr and therefore trying to figure out options on How to accomplish this.
I plan to use these cameras in my summer house which is basically shut down for 6 months of the year. I have one socket that’s not shut down that runs my current nvr which has poe ports so it’s not a problem today.
So, my question is how you guys would set this up? Are there any switches out there which run both poe and poe+ that I connect all 4 cameras through or do I need to look into other options?
As the live socket which runs the dvr will be far from where I plan to put the SD49225T-HN, I need to power it with poe somehow.
Thanks!
Thanks!
