I am trying hard to configure below Hikvision products:
Door station: DS-KV6113-WPE1(B)
Indoor station: DS-KH6320-WTE1
Hikvision NVR: DS-7608NI-K2/8P
Now I have some queries which I want to ask from you.
1. Is it possible to connect my door and indoor station with above mentioned PoE NVR? And can I still use HK-Connect? Will everything connected with NVR work, IP cameras and this video intercom kit?
2. If connecting the intercom with NVR is possible then which IP address should I give to the indoor and door stations? Internal IPs of the NVR or my local network IPs?
3. I want to use indoor and door stations via wired network, I mean through PoE and want to disable/not use WiFi.
Could you please answer the above questions? I am really having trouble in configuring these components.
