- May 10, 2018
- 4
- 3
I'm hoping someone here can help me trouble shoot my problem.
I'm trying to hoop up a couple Hikvision IP PoE cams to an NVR. I wanted to make my on cables so I ordered CAT5E 350MHz copper cable. I made three 30 foot cables and when I hook the camera up, the nvr sees them (says "detecting") but it will not connect. If I make a short cable (under 15') it works perfect. I know the first thing to check would be the crimping at the connectors but they look perfect and test good with a tester. Any ideas why the longer cable will not work?
