I have 2 4231EM-AS. I also have a 150w Ubiquiti poe switch.
One camera when plugged into the Ubiquiti switch will power up and work fine, while the other identical camera will not power up on the ubiquiti switch. Same cable and port, one camera plugged in at a time. It gets weird when I disable power on that port and then add a poe injector in the mix, the camera that would not power up now will power up.
Anyone have any suggestions? Should I just send the one that is acting squirrely back to Andy, or is there something I can do on my side?
Frank
Frank
