I have installed a HIKVISION DS-2CD2342WD-I camera http://overseas.hikvision.com/en/Products_accessries_159_i5636.html on a tree where I used to have a Logitech Alert 700e outdoor camera. I am using the Logitech flat ethernet cables with a connector that is well sealed. I tested the camera first in the house and it worked well when connected to a TP Link TL-PoE150S injector http://www.amazon.com/TP-LINK-Gigab...&qid=1463710409&sr=8-2&keywords=poe++injector. With the camera on the tree and connected to the 150ft cable, the camera would not come online with the TP Link. You could sometimes ping it but response was slow and only maybe 3 pings in a row, ~97% data loss. I bought the camera inside and connected to ~40ft of cable and it was ok. I then connected the camera to my old Logitech PoE / Powerline power supply and the camera worked and is working now connected to the 150ft cable. This is I believe this is the power supply http://www.ebay.com/itm/New-Logitec...0n-/112012666640?_trksid=p2141725.m3641.l6368 , I would rather not use the old Logitech power supply as these cameras are now failing quite regularly.
Thinking the TP Link PoE injector I bought was not suppling the camera with enough power, I then bought a iCreatin Wall Plug PoE injector http://www.amazon.com/iCreatin-Inje...psc=1&redirect=true&ref_=od_aui_detailpages00 as the reports seemed to suggest a more powerful output. With the iCreatin injector connected to the camera on the end of the 150ft cable, I would get a picture for a few seconds, motion would be then get jumpy and then I would lose the picture with a message like instability reloading.. I connected the Logitech Alert power supply and the camera is now working again.
Is there a PoE injector that you think that will work in my situation?
The 150ft enters the house next to my electrical / network panel and I would rather not use the Logitech Powerline power supply.
Suggestions?
Thank you.
Suggestions?
Thank you.
