If I plug my meter directly into the POE injector with a 5" cable (five inch cable) it reads 55 volts, 5.0 watts. If I plug my meter directly into the full length of CAT6 on my roof, it reads 70 volts, 0.0 watts.
Both tests involved connecting the POE injector with one of the ethernet inputs on the back of the Reolink NVR.
If I test the POE injector WITHOUT having it plugged into the Reolink NVR, I see about 48 volts regardless of where my meter is plugged in. What gives.
I will retest next week when my Ubiquiti GP-V480-032G arrives!
