I have a Dahua dome PoE camera which sits on the front of the house. It has a PoE injector that has been running fine into a wifi extender (that has an ethernet outlet). This connects into my local network so i can see the camera on Blue Iris.
I have two Eero 6 pros and bought the 3rd one to see if I can get a better signal in the garage. It has spare ethernet ports on the rear. Hooked it up. Eero shows it has a device connected. Camera has power as I can hear it reset.
But the light on the PoE injector is red - which usually indicates an issue. And I cannot see the camera on my local network at all via Blue Iris.
I checked the cables and they are all OK - what else could I check? I've assumed I can just plug the cam into the Eero with the injector as normal and it'll pick up a signal.
This is the injector I have, which works fine with the PoE extender
For additional context (in case it matters)...!
So the NETWORK seems to see it, it seems. It shows as connected in the Eero app, and the Dahua desktop app shows the device with an IP. Just I can't get it to find in BlueIris at all. Tried searching with no information, and various combinations of IP/ports.
Thanks in advance!
- My 'base' Eero is connected to my Unifi switch. Is there something different I should be doing on the switch? The Dahua does not appear as a device in my Dashboard. The base Eero itself does.
- the Dahua 'Configtoo' windows app shows the camera listed, including an IP address/port. However, when I go to that website it fails and no login to the camera. When I was using the wifi extender, this would take me to the camera login site.
Thanks in advance!
