Hi
please recommend me an ip camera in door with free/low cost cloud recording from amazon USA or Germany.
Thanks
Thanks
Hi
Thanks
Thanks . how much is the cloud subscription ?It's a re-branded Dahua
I have no idea, as I do not use their cloud or any cloud; all my cams are connected to Blue Iris, VMS software running on a PC.Thanks . how much is the cloud subscription ?
just monitor no storage for recoding . thanksThere's a "free" cloud at the bottom of that page but I do not know its features or terms.![]()
14 days more than enough, camera + subscription also very cheap. Internet where I am is already slow so thanks![]()
Wyze Cam v4 | Wired Indoor/Outdoor Security Camera
Wyze Cam v4: 2.5K QHD resolution, Color Night Vision, indoor/outdoor use, 24/7 recording with MicroSD. The best "never wonder again" security camera ever made.www.wyze.com
You should be able to buy it from amazon. Their cloud storage apparently will delete recordings after 14 days but otherwise it is quite cheap.
Keep in mind the video quality from this is not going to be amazing, and stability probably won't be good either since it only operates on 2.4GHz wifi. I'd recommend having an SD card in it for local storage so that it will still be able to record even if the wifi is sucking.
I have 4 of these for 3 years connected to Blue Iris ==>> Amcrest ProHD 1080P WiFi Camera 2MP (1920TVL) Indoor Pan/Tilt Security Wireless IP Camera IP2M-841B (Black)
It's a re-branded Dahua and is ONVIF compatible, provides RTSP, is 1080p (Full HD), IR, 2-way audio, has pan/tilt/digital zoom, record to micro SD card, wired or wireless, great with Blue Iris, VLC, etc. Comes with wall/ceiling mount, 1/4"-20 tripod mount female insert on bottom. Available in black or white for under $40, can be mounted upside-down and the image inverted as needed.
P.S. - Welcome to IPCT !![]()
@TonyR Any chance you can point me to steps to enable two-way audio for Amcrest IP2M-841B in BI5? I'm having trouble finding those config steps.
LAN, WiFi, PSTN for communication;
28 wireless detectors+8 wireless keyfobs+4 wireless sirens+2 wired zones+1 alarm out+1 wired siren, 150m transmission distance(open space, no interference)
4CH IPC surveillance
30s voice message
RFID reader(arm and disarm)
3.7V/1900mAh Li-ion backup battery up to 4 hours when main power off
4.3'' TFT screen
Max 128GB SD card for video recording
Airfly technology, 2-way dynamic 128-bit AES encryption
Globally control. Know what's happing 24/7, preview and playback video, receive notifications via DMSS anywhere anytime
Entry and exit delays
Easy installation, no wiring. No contracts and monthly fees
1 Video alarm control panel, 1 PIR detector, 1 curtain PIR detector, 2 door/window detector, 1 remote control, 1 panic button, 1 IPC-A35
| ARC5402A-W | |
| Name | Video Alarm Control Panel |
| System | |
| Main Processor | High-performance industrial embedded microcontroller |
| Operating System | Embedded LINUX |
| In and Out | |
| Wired Zones | 2 on-board zones |
| Wireless Zones | 28 wireless detectors, 2-way communication, transmission range up to 150m open space |
| Alarm Output | 1-ch relay output |
| Tamper Funtion | 1 tamper switch |
| Wireless keyfob | 8 wireless keyfobs |
| Siren | 4 wireless sirens + 1 wired siren |
| Storage | Max 128GB micro SD card for video recording, USB device to backup video |
| ID Card | RFID reader(arm/disarm) |
| Network | |
| Network Function | TCP/IP, DHCP, WIFI, P2P, IP Search(Support IP camera), DMSS |
| Interface | |
| Network Interface | 1 RJ-45 Port(10/100Mbps) |
| RS485 | 1 Port |
| PSTN | 2 groups PSTN, support Contact ID standard protocol alarm |
| Wired Siren | 1 wired siren(12V/0.5A) |
| Auxiliary Power Output | 1 auxiliary power output(12V/0.5A) |
| Reset | Insert two ends of cable into the holes to reset |
| USB | 1 USB 2.0 port to record or upgrade |
| Audio and Video | |
| IP Camera Channel | 4 Channel |
| Compression | H.264 |
| Resolution | D1 |
| LCD Screen | 4.3 inch TFT screen, 480*272 resolution |
| Audio In | 1 ch audio in for 30s voice message |
| Audio Out | 1 ch audio out for voice and alarm broadcast |
| Upgrade | |
| Remote Upgrade | USB disk or ConfigTool to remotely upgrade |
| General Parameters | |
| Main Power | DC12V/2A |
| Backup Battery | 3.7V/1900mAh, Li-ion |
| Power Consumption | ≤5W |
| Operating Temperature | -10℃~ +55℃ |
| Humidity | 10% ~ 90% |
| Device Dimensions | 216*118*28mm |
| Device Weight | <1kg |
| Installation | Wall mounting |
| ARD1231-W | |
| Name | Wireless passive infrared sensor |
| Detection | Passive infrared |
| Detection Range | 12m×12m, 90° |
| Alarm prompt | Red LED, can be set to switch off |
| Sensitivity | Two level (jumper) |
| Wireless Frequency | 433/868MHz |
| Transmit power | 10dBm |
| Transmit distance | 150m open area/no interference |
| Pet immunity | ≤18Kg |
| Resistance light | 6500LUX |
| Working environment | -10°C~+50°C, humidity <95° |
| Overall dimensions/weight | 105mmx62mmx41.3mm/0.1kg |
| Tamper | Unit protection and leaving-wall protection |
| Power | 1xCR123A battery |
| Installation height | Wall mount, 2.2-2.5m |
| ARD1611-W | |
| Name | Wireless Curtain PIR Detector |
| Detection Range | 10m/15° |
| Alarm prompt | Notification LED light, can be set to switch off |
| Sensitivity | Two level (jumper switch) |
| Transmit distance | 150m, open area/no interference |
| Overall dimensions/weight | 99mmx52mmx35mm/0.1kg |
| Installation height | Ceiling/Wall mount, 2.2-2.5m |
| ARD311-W | |
| Name | Wireless door sensor |
| Motion distance | 25-40mm |
| Transmit Power | 10dBm |
| Transmit Distance | 150m(open area/no interference) |
| Tamper | Front cover and rear cover protection |
| Installation Way | Screw and glue |
| Dimensions | 84*39*22mm |
| Weight | 0.1kg |
| Temperature | -10°C~50°C |
| Humidity | < 95% |
| Installation | Screw or glue to mount |
| ARD800-W | |
| Name | Panic Button |
| Trigger Alarm | Button pressed down |
| Alarm prompt | Alarm success: green LED on |
| Alarm failure: red LED on | |
| Transmit Distance | 150 meters(open area/no interference) |
| Indoor 30 meters, 1 wall capability | |
| Power | 1xCR2450 battery |
| Dimensions | 42*43.8*13mm |
| Weight | 0.05kg |
| Temperature | -10°C~55°C |
| Humidity | < 95% |
| Installation | Hang on the neck or 3M glue to mount |
| ARA22-W | |
| Name | Remote keyfob |
| Working Voltage | DC3.0V |
| Key | Away Arm/Stay Arm/Disarm/SOS |
| Ingress protection | IP20 |
| Dimension | 62*30*14mm |
