- Nov 18, 2016
- 8
- 1
I just purchased the turret camera that nayr reviewed (IPC-HDW5231R-Z). This is my first IP camera. I take the camera out of the box, hook it up to my POE switch and the POE switch is connected to another non-POE unmanaged switch. Nothing. So I disconnect from the non-POE switch and connect the POE switch directly to the router and the camera works immediately.
I start using the config tool and it pops up, I can see video and everything is great. I can login to the camera with the net interface and the camera shows up on my network. I come back the next day and can't find it anywhere and the config tool says no devices are found. What have I done wrong?
