9 9th Power n3wb Apr 20, 2022 15 4 Tampa Nov 15, 2023 #1 Can anyone please tell me if the specs are good on this camera? Its a 4mp with analytics and color night vision. Any opinions would be greatly appreciated.
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,407 48,316 Alabama Nov 15, 2023 #2 Not bad (sensor size to resolution is good) but what's the price? You do know this has no IR for night time viewing and if ambient visible light is not sufficient it uses its built-in white LED's, correct? Reactions: Parley and bigredfish
9 9th Power n3wb Apr 20, 2022 15 4 Tampa Nov 16, 2023 #3 TonyR said: Not bad (sensor size to resolution is good) but what's the price? You do know this has no IR for night time viewing and if ambient visible light is not sufficient it uses its built-in white LED's, correct? Click to expand... Yes, i know it doesnt have IR. Price is $135. Fps is 30
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,407 48,316 Alabama Nov 16, 2023 #4 FWIW, this camera, also 4MP and 1/1/8" sensor, will run in color as low as .0007 lux, just .0002 lux more illumination than the COR-IP4TRFU but also has IR, for $159.99 ==>> Loryta Outdoor Security 4MP Ultra Low Light Starlight+ WDR IR Turret AI IP Camera SMD 3.0,IP67 Weatherproof, Support POE and ePOE,Built-in Mic,Vehicle and Human Detection,S3 Version IPC-T54IR-AS 2.8mm For $30 more get a 2.7 mm–12 mm Motorized vari-focal Lens ==>> EmpireTech 4MP Ultra Low Light IP Camera,Starlight IR Motorized 2.7mm-12mm Lens Turret Camera,IP67,Built-in Mic,Support POE and ePOE,Vehicle and Human Detection,S3 Version IPC-T54IR-ZE White Last edited: Nov 16, 2023 As an Amazon Associate IPCamTalk earns from qualifying purchases. Reactions: VorlonFrog
Parley Known around here Dec 19, 2015 6,435 19,830 Cypress, California Nov 16, 2023 #5 How come I cannot see what MM the lens is in the original post. I have to be looking right by it.
