- Jul 31, 2015
- 167
- 12
This has probably been asked before but maybe not in thesame way. I finally decided to use white light daytime mode with no IR on mycarport cam for both day and night. It is an LTS Platinum CMIP1142W-28 runningthrough a TP-LINK TL-SF-1008P Switch to my BI4 computer. All I want to do nowis adjust the brightness between night and daytime. If I use the same settingsit will be too dark at night or too bright during the day. I tried setting theschedule up via BI4 PZT control but it just uses the last brightness setting andwon’t change when I manually select night/day profiles.
One clue maybe is in BI4 video setup for that camera, the Find/Inspectsays it’s a Generic RTSP H.264/MJPG/MPEG4. And under PZT control I enablepan/tilt/zoom and other controls but it doesn’t seem to know what camerainformation to put in the pulldown next to network IP.
I saw the curl thread but had trouble with a missing dllfile so I baled. I’m not sure if that is the correct route anyway.
I hope this makes sense, thanks for any help.
