Please help confirm the issue regarding simultaneous output of the three-camera IPG-X8-WE2Q
chinkit
Nov 17, 2025
1
Malaysia
I recently purchased a“Three-Camera Board System – IPG-X8-WE2Q” from JFtech/XiongMai. I have encountered a critical issue that I am unable to obtain RTSP video streams from all three cameras simultaneously.
I used the pattern channel=1&stream=0.sdp? and then changed the channel and stream parameters accordingly. But no matter how I configure it, I can only get the video from the first camera. The other two channels do not give any output.
I have thoroughly checked hardware connections, network, client software, and the usual configurations, so it is unlikely a usage or configuration mistake.
From a technical standpoint, since this module supports three sensors, outputting three RTSP streams simultaneously should definitely be feasible in the architecture. Therefore, I suspect that this may be caused by some firmware feature not enabled, conflicting logic, or incomplete initialization of certain channels.
I kindly ask for help here to see if any of you guys have experience dealing with this IP camera module before and know what should be the correct RTSP link to be used for getting the streams from all three sensors.
Appreciate your help. Thanks in advance.
Have you tried viewing the stream using VLC media player? That app tends to work when other apps or browsers don't. I have no idea if it will in this case, but it would certainly be near the top of my troubleshooting tips/methods.
