Here's our new setup so far (see picture). This is a dual NIC BI server.
The LAN will plug into the back of the server.
With the second port (separated), I will run a cable to Keystone 1 (red line in picture). Then using a patch cable, connect Keystone 1 to port 1 of POE switch (yellow line in picture).
If the above is correct, my second question is about the NanoStation Loco M5 and it's POE adapter for cameras across the street.
Please see the wiring diagram picture. Where it shows "ToLAN." Is it correct that I need to plug the "ToLAN" into port 2 of the POE switch and the other run is for the antenna?
Please let me know if you need any clarification, and thanks in advance for your time and help!
