- Apr 13, 2016
- 16
- 1
I recently upgraded my pc and updated to the latest BI. Im mainly a linux guy but I like blue iris so much I maintain one windows machine for it. I used the guide here to pick out a good cpu and things have worked out nicely. Im sitting around 30% cpu when my old pc on win7 with bi4 was maxing out constantly.
I discovered I can play .bvr files directly in MPV. The only issue is its too fast, if I slow it down to around 60% speed it works perfectly. I know I can convert and export within BI but this is more convenient for me. Has anyone experienced this? Is the video actually getting recorded at a faster speed or is it just an incompatibility issue?
Heres the output I get from MPV when I successfully play a .bvr video,I am considering working with vlc or mpv to try to get .bvr properly supported:
mpv driveway.20220428_083009.bvr ✔
[ffmpeg/demuxer] h264: Stream #0: not enough frames to estimate rate; consider increasing probesize
[lavf] This format is marked by FFmpeg as having no timestamps!
[lavf] FFmpeg will likely make up its own broken timestamps. For
[lavf] video streams you can correct this with:
[lavf] --no-correct-pts --fps=VALUE
[lavf] with VALUE being the real framerate of the stream. You can
[lavf] expect seeking and buffering estimation to be generally
[lavf] broken as well.
(+) Video --vid=1 (h264 3840x2160 25.000fps)
No video PTS! Making something up. Using 25.000000 FPS.
Ignoring further missing PTS warnings.
VO: [gpu] 3840x2160 yuv420p
V: 00:00:02 / unknown (1%)
[ffmpeg/video] h264: Invalid NAL unit 0, skipping.
V: 00:00:08 / unknown (1%)
V: 00:00:25 / unknown (4%)
[ffmpeg] NULL: pps_id 3199971767 out of range
V: 00:00:30 / unknown (5%)
V: 00:01:59 / unknown (19%)
V: 00:02:03 / unknown (20%)
V: 00:02:15 / unknown (21%)
[ffmpeg/video] h264: data partitioning is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which h
as not been implemented.
[ffmpeg/video] h264: If you want to help, upload a sample of this file to VideoLAN File Uploader and contact the ffmpeg-devel mailing list. ([email protected])
V: 00:02:26 / unknown (23%)
V: 00:02:30 / unknown (24%)
[ffmpeg] NULL: SEI type 43 size 896 truncated at 88
[ffmpeg] NULL: SEI type 43 size 896 truncated at 272
V: 00:02:33 / unknown (24%)
V: 00:02:37 / unknown (25%)
V: 00:02:40 / unknown (25%)
V: 00:02:47 / unknown (27%)
(Paused) V: 00:02:50 / unknown (27%)
