This is a weird issue. I just got a Reolink RLC-410 camera and I had to find new IP camera software because my iSpy setup kept crashing when I tried to use the high quality stream with this camera.
I found Blue Iris and I'm currently in the demo period before deciding to purchase. So far it is the best alternative that I've found.
Anyway, my problem is that recordings from when the camera is in B&W night vision mode play back with terrible stuttering and sync issues. The audio seems to play properly, but the video alternates between fast-motion and then a static image as the audio catches up.
Strangely enough, recordings in the color daytime mode play back smooth as silk.
I'm recording in the .bvr format using the direct-to-disc encoding option. New files are stored on an SSD, then archived to HDD (I haven't reached that limit yet though).
Any help would be appreciated.
