Plate Recognizer for ALPR
DsineR
Getting comfortable
Mar 25, 2018
492
762
FL
Anyone using this new feature in BI? Found under the camera settings - trigger - artificial intelligence. For now, looks like the only benefit to enabling is have the license plate info show up on the Alerts tab. Takes a little work to the vehicle aligned within the Alert window.
You must register with Plate Recognizer for a key, then enter key into BI window.
Reactions: pb11186
IPC-HFW5231E-Z12E purchased from Andy. Seems to be the current favorite for LPR usage, several threads here in the LPR section covering details.
I see it's a free service for 2,500 plates a month. My quiet residential street gets about 3,700 plates a month from OpenALPR's free CloudStream service, although a portion of them are duplicates either from parked vehicles or from slow vehicles. Once the plate event is captured, what does the service allow you to do with the data? Is it searchable and quantifiable?
I have not checked out the offerings from Plate Recognizer, except for the BI integration. So far, very limited use with BI - the captured plate is shown on the alert window as shown in the original post.
Could be promising. I wonder if IPC-HFW5241E-Z12E would work well with this.
I'm testing Plate Recognizer via Blue Iris on a pair of Dahua Z12's.
I am testing against OpenALPR running on same cameras.
After a few hrs testing :
Open ALPR : 36/36 (100%) hits with 97% (35/36) accurate plate reads.
Plate Recognizer 8/36 (22%) hits with 12.5%(1/8 ) accurate plate hits.
PR does not seem to working at all now?I will need to try and work out why.
I think the issue with PR is that it is not capturing the image at the right time, so I will probably have to make adjustments to the cameras.
Reactions: TL1096r and DLONG2
Do you see any major differences between HFW5231E-Z12 & Dahua HFW5241E-Z12E?
Reactions: pinko
Both are great cameras.
The Z12E has a few more AI features like Heat Map and People counting.
There's really nothing between them, day or night.
Reactions: Arjun and TL1096r
I’m trying to use a IPC-HDW5231R-ZE for ALPR with playerecognizer.com and it is not at all working for me.
Any suggestions?
F537064A-D462-4BBB-9E73-6E9956DDA80B.jpeg D21CC9DD-9B07-4512-98D1-96DA4DD74808.jpeg
@JNDATHP. I've disabled PR for now. I will mess around with it to get better detection at a some point.
I have both cameras set up to capture passing vehicles (image). I only need one camera for this.
I will set the other camera up to get plate captures for vehicles entering/leaving.
To get my cameras dialed in for PR, I think all I needed to do was to get the camera to capture a good JPEG (capturing the plate), using combination of make time/detection zones.
IMO you might need to increase the size of your detection zones for better jpeg captures. Once your getting good jpeg captures, PR should give better results.
You can see a full dashboard on Plate Recognizer website. You can search, filter, flag, etc. the license plates captured. I'd expect they'll make this more robust in the upcoming weeks.
Sadly, Plate Reconizer is not even close to being any sort of competition to OpenALPR.
I wanted PR to be great, its not. Lacking in so many areas. :(
IMO Blue Iris integrtion should have went with OpenALPR. Perhaps Ken will add this integration at some point in the future.
