Im about to buy some outdoor cameras but not sure what to go with regarding plastic or metal housings? Can the plastic versions handle UV/direct sunlight ok? I have had metal ones in the past and the powder coating has begun to peel off which is not a good look. What are you all using out in the weather and how long has it lasted?
