Plastic mounting bracket for eyeball 8mp cams VC-ETI08TMG1-IA
hdtvjeff
Nov 19, 2014
218
19
Is this mounting plate useable for all Dahua or Dahua eyeball variants if the eyeball cam did not come with one of these? VC-ETI08TMG1-IA
It seems the newer 8mp touret cams like valucam 4k/20 fps does not come with this part
Is there a part number or a source to order these from?
Thanks
jeff
I don't think that particular camera uses that ring. If you look at the Valucam C-ETI08TMG1-IA shown at Ama$on you unscrew the single Torx screw located in front of the bottom ring, lift the ring, remove the camera, mount that ring to wall or junction box then replace the camera and ring, connect the camera, aim the camera and then LASTLY tighten the Torx, usually with a supplied wrench.
Thank you ! I know the earlier version which I have 20 of VC-ET08TMG1-IA all had the ring which made installation a snap, literally
