So I started some time ago with BI and a couple of Dahua cams and have been pretty happy so far.
I'm just about to add an extra cam to get some front door images. - looking at the IPC-T5442TM-AS in the 3.6 version.
My first question is for the location of the new camera. Does this look ok?
The red circles are existing cams and the green would be the new one.
Untill now I never really thought about fov 90 and turning the cams around, but now I'm thinking I should move my carport camera to get a better angle.
Current location and image
So before I pull out the installed cable and move around wouldn't I be correct in perhaps turning it vertical and then perhaps either move it down to the middle (Location A) or move it to the center (Location B)
Any thoughts greatly appreciated
/Kim
/Kim
