Placement - long delayed cam installation
flyyboyy
Sep 30, 2018
8
9
Arizona
Long delayed project ahead: 3 or 4 years ago, I picked up a couple of 5442 3.6 from Andy. They've been sitting on the shelf, still in original boxes, waiting for me to get up in the attic for cabling. That never happened. . . Now, gotta get in gear to get it done. Last week, my son's truck (sitting on the driveway) was broken into. Nothing taken, just seems like maliciousness for breaking out a side window.
My question has to do with placement. I'm thinking, based on all my reading from ipcamtalk, that the two best places would be on both sides of the garage at about the 7ft, level or a bit below 8ft. I know, "LOWER IS BETTER" though a couple of things come into play. First is that the lower one (1) would need to be fed through a hole drilled through the steel plate, (2) that there is a fear it could get whacked and knocked off hanging down into the garage door opening, and (3) the amount of direct afternoon sunlight (more on this in a minute.)
The upper location would have less fear of getting hit, etc, would be easier to feed the cable to, plus it would be protected from the setting sun for a bit longer each day.
Now, about the afternoon sun. Plain and simple, it's screaming hot in the Phoenix area in the summer, and with with intense direct afternoon sunlight in all seasons. (See what it has done to my fascia?) I wonder about the durability of any camera facing afternoon sun. Is the higher location better if it's possible to give it an extra hour or two from direct sunlight?
Open to any thoughts and/or ideas! Thanx - flyyboyy
The upper location would be my choice, for the reasons you mentioned plus.....
You could anchor the correct camera junction box with at least 2 anchors in the mortar joints (avoid drilling any brick) and route the cable straight up into the soffit and into the attic, bring cable into bottom of box with drip loop (or at 225° or 135° with 0° being straight up), plug with threaded gland or duct seal. Use dielectric grease on the Ethernet connection of the camera. :cool:
Perfect! Thanks! That was my first choice, thinking 6 or 8 inches would not make a huge difference for the "hoodie" bums.
Anyone: Anything definitive about direct afternoon sun on cameras (and any ideas to mitigate if so)?
I like 2 cameras watching the driveway .. one on each side of the garage door
This way you can point both into the center if the driveway and at worst one camera could be blinded by then sun at any one time ..
1783922844325.pngI
I just left the predecessor of the 5442, the 3241T-ZAS on the shingles in the sunniest part of the year for 2 weeks with 90 degree heat and humidity looking straight up ( a little north) to keep sun out of CMOS sensor. . It was hot to the touch. I mean baking. the thing never quit.
I'm sure the Heat in AZ will shorten the life of nearly anything faster than northern states.
I'm thinking the Brick might act like a Heat Sink and absorb heat from the metal camera.
Or put a homemade Heat sink behind it
It has lived a life of luxury facing north in Minnesota with no Sun on it under the soffit overlooking the garage.
I wanted to see if it would Die. I couldnt kill it. So it's back on duty looking at the deck and patio door.
