fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
When you spend time and money on security cams, you want them to be reliable and effective. You can carry on with your sricams/foscams...1080p cameras are CHEAP. PC's are CHEAP. The cost difference between a junk setup and a good one is about 300 dollars, probably less.OK. I dont dispute that. BUT, it works! And it works great! I think the latest bios update has a boot on power option.
You know boys, I'm not exactly running the Green Door at the Pentagon. And I doubt you are either. Carry on!
