Podagrower
Pulling my weight
I'm considering using Pi-hole to block ads on my network. I'm a noob with this kind of stuff, but want to press forward because I'm tired of trying to block ads on my browsers, phones and smart TVs. I tried to block ads using my Netgear R7000 router, but it's not up to the task--allows only a limited number of keywords to block and doesn't seem to block any https addresses.
I don't have a linux machine of any type--no raspberry pi either. But I have one Win 10 Pro machine that I could activate Hyper V and install Docker on, but it's my dedicated Blue Iris machine...I haven't used it for anything else. I'm not using a VPN on this machine (I know I should, but both my router and my skills are limited). Is it ill-advised to run Pi-hole (using Docker) in the background on a dedicated Blue Iris machine?
I'm running Blue Iris and Home Assistant (inside Docker) on the same machine and don't have any issues. Pi Hole isn't resource intensive so I think if your computer has a little spare capacity it should be fine (obligatory it will probably run better on an SSD statement here). I'm running Pi Hole on a Raspberry Pi and I do love it. I get a little self righteous at work when there are 20,000 ads per web page to the point that I've considered doing Pi Hole on my workstation.
