Hey Guys,
For the most part, my network is working just fine. I went with the VPN topology because the MiFi routers are using SIM cards/IP's that sit behind NAT.
My nodes are remote (Rural) and this seemed like the most economical way to do business for a non-commercial setup.
My question for you is this: If I was to add an NVR of sorts, where would be the best place to put it? I am always cautious about speeds through the VPN and bandwidth.
At present, I'm just using VLC/RTSP to connect to cameras however I want to expand this to some kind of server infrastructure.
I want to keep it as simple as possible, maybe set up some file shares at the router locations, then only grab recordings on request? I dunno
After advice for expansion.
