- Nov 29, 2017
- 45
- 46
I want to move my turret camera because the current setup is causing problems. The sunshade reflects the IR, which gives less night vision, and the lighting spot does not help (beginner's mistake from a few years ago). I am going to transfer the camera from the canopy to the wall (see photo), so I will no longer be bothered by the sunscreen and spotlight. I'm just unsure which mount is best for this application. It will be the PFA130-E or PFB203W.
The camera will hang approximately 200cm / 6.7 feet from the ground in the new location.
Advantages of the PFB203W in this situation.
-the lens is slightly more shielded from rain.
-Probably just a slightly better angle
The disadvantage of the PFB203W is that it is quite easy to pull it off the wall because it is mounted low, but this is a lot more difficult with the PFB203W.
Benefits of the PFA130-E
-Probably more beautiful optically
-More difficult to pull off the wall
I am curious about your advice
