Hi All,
Was just randomly thinking if it would be an idea to request a perspective multiplier function added into BI, although these days using DS it's removing loads of false triggers it would be great if you could manipulate the min obj size and travel distance in a more dynamic way. Wouldn't expect this to be fully mappable in little zones across the cameras view (as with the detection zones) but a simple directional arrow which you could rotate to match the camera perspective and a multiplier value assigned so you could then make the min size\travel distance perfect for the longer distances without it then picking up an ant which was closer up (ok ant may be a bit far fetched but you hopefully get what I mean lol).
Good, bad or just plain stupid idea?
Haven't sent it through as a feature request or anything as yet.
Cheers,
Mike
Cheers,
Mike
