- Jan 4, 2015
- 63
- 4
I run blue iris with 6 hikvision poe cameras. a couple of months ago i noticed one camera would give the 'connection failed' error in blue iris. I also could not log in to the camera directly. then after a period of time (an hour or so), it re-connects and works fine. but this has happened several times -- every other day or so -- and i'm looking for tips to trouble shoot this.
I swapped out the camera and this still happens on the same cable/poe port.
I tested the cable run with a cable tester and it seems fine.
today i swapped the port on the poe switch to a different one. too early to tell if that makes a difference. there's another camera on this same 4 port poe switch and it has never lost connection.
anything else to try? since I changed the camera, it has to either be the cable or the switch, correct?
thanks for any tips.
